lifting info
lifting info
so im starting to save so I can do my lift. More then likely going to do either the super lift or BDS 6" kit along with a 3" body lift. I was told by a shop here that I can fit 35s with this combination with minimal trimming. Is this true or not? I really would like to go with a bigger tire the 33s.
RE: lifting info
you will rub frame if you try to turn. other than that, yeah you can fit 35s.
RE: lifting info
Just dont wheel it....you'll break stuff real easy with 35s.
RE: lifting info
yea i hadnt planned on doing any wheeling with it.....another thing...do I have anything to worry about with wear and tear on the motor??
RE: lifting info
You will more than likely need to re-gear the diffs as well.
RE: lifting info
i know about the rear end...i planned on doing 4.10s
RE: lifting info
you should be good to go, but yeah the engine is under more stress, one thing is it will lowwer mileage and power significantly
RE: lifting info
Thats why you re-gear...keep the mileage and power the same as (or better than) stock. The only real difference after the lift and regear should be braking...but that can be upgraded too
RE: lifting info
ORIGINAL: jagblazer01
RE: lifting info
If he keeps it 4wd
