lifts with 265/75/16's
Old Mar 31, 2008 | 08:24 PM
cowboy717's Avatar
cowboy717 is an unknown quantity at this point
Default lifts with 265/75/16's
anyone got any pix of a blazer with a lift that will fit 265/75/16s??? wonderin if a torsion bar crank and an addaleaf will work? or maybe the 2" lift from rough country?
thanks
Old Apr 1, 2008 | 01:24 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
Default RE: lifts with 265/75/16's
I got tbar and shackles I am planning on doing a 2" body lift with 265/75/16. they are supposed to be about equal to 31.5" diameter based on a tire size calc and convert.
Old Apr 1, 2008 | 01:34 PM
WolfPack's Avatar
The width won't be much of a problem. The only issue is that a 265 tire (at least on my general grabbers) translates to actual width of 10.7 inches. A 31x10.50 grabber is only 10.2' wide. So you might still have some rubbing issues at full-lock turn just from that extra width. The height shouldn't be a problem with a 2' BL or 2' lift. You might need 3' though...2' BL and 1' shackle/t-bar.
Old Apr 1, 2008 | 01:49 PM
jphayes921's Avatar
what about with a two wheel drive extreme wheels. they have a 4" bs and I believe are 8 or 9" wide?
Old Apr 1, 2008 | 03:33 PM
WolfPack's Avatar
I've got 4.5' backspace and 15x8s. I trimmed/lifted and still rub at full lock. 10.5s are prettttyyyy big.
4' of backspace will cause you to rub more than me. or you'll have to trim more than me.
RedNeckWagon360
Apr 3, 2009 11:53 AM
Canadian
Tires and Wheels
Dec 21, 2007 10:08 AM
cowboy717
Lifting Tech
Aug 22, 2007 11:33 PM
Spazz
Tires and Wheels
Jan 15, 2007 08:25 PM
ivannj
Engine & Internal
Feb 9, 2006 06:02 PM
