mild lift for 30x9.50-15 tires
i am considering a mild lift for a set of 30x9.50-15 tires mounted on a set of 15x8 black rock type-d rims with 4.5'' backspacing, i was thinking maybe building own rear shackles for 1 1/2'' lift and doing the torsion bar adjustmaent up front, is 1 1/2'' too much for the front, do not want to wear anything out prematurely, i have read that 30'' tires do fit without rubbing but i thought a mild lift 1-1 1/2'' would make sure they dont....any thoughts on this?? its a 97 4 door blazer!
it is basically like you said: 30's fit with out issues. playing it safe is a good call, but you shouldn't need any extra in the rear unless it is just to level out the look. an inch or 1.5 up front should allow you to bounce them around pretty hard without issues. just know that they will stick out a bit
