mild lift for 30x9.50-15 tires
Old Jan 2, 2011 | 07:23 PM
Jerb's Avatar
Jerb is on a distinguished road
Default mild lift for 30x9.50-15 tires
i am considering a mild lift for a set of 30x9.50-15 tires mounted on a set of 15x8 black rock type-d rims with 4.5'' backspacing, i was thinking maybe building own rear shackles for 1 1/2'' lift and doing the torsion bar adjustmaent up front, is 1 1/2'' too much for the front, do not want to wear anything out prematurely, i have read that 30'' tires do fit without rubbing but i thought a mild lift 1-1 1/2'' would make sure they dont....any thoughts on this?? its a 97 4 door blazer!
Old Jan 2, 2011 | 08:13 PM
ABN31B's Avatar
it is basically like you said: 30's fit with out issues. playing it safe is a good call, but you shouldn't need any extra in the rear unless it is just to level out the look. an inch or 1.5 up front should allow you to bounce them around pretty hard without issues. just know that they will stick out a bit
Old Jan 2, 2011 | 08:20 PM
mdehoogh's Avatar
You should be alright with what you said. Most people are okay with 30's and no lift but since you're on wider wheels, you may need to lift some. You should be alright with 1-1.5" but if your springs and bars are worn down it may be necessary to lift higher. I just recently put on 31x10.5 on 4" backspacing and right now I'm up about 4.5 full turns on the tbar which is roughly an inch. I also cut my fenders back and to be honest, that helped a lot more than the torsion bar crank did
Old Jan 2, 2011 | 08:43 PM
Kamelot314's Avatar
Kamelot314 is on a distinguished road
i have a 97 Blazer 4 doors, with 30x9.50r15 and 15x8 Wheels, and you need the torsion lift and shackle lift if you don't want to get rubbing at full lock
Old Jan 2, 2011 | 09:55 PM
Jerb's Avatar
Kamelot314, may i ask what backspacing you are using on your wheels?
Old Jan 3, 2011 | 05:02 AM
Kamelot314's Avatar
Jerb : 4.5
Old Jan 3, 2011 | 06:13 PM
Jerb's Avatar
Thanks....might try and find a 15x8 wheel with 5'' backspacing, if not then the 4.5 should work!
Old Jan 3, 2011 | 07:13 PM
ABN31B's Avatar
camaro rims... 16x8 with 6" back spacing and the 4.75 5 lug pattern...
get em used for the same price or less as those shipped...
dougg01
Lifting Tech
19
Jan 21, 2010 02:48 PM
DSMayo
Tires and Wheels
Oct 17, 2009 07:49 PM
muszyngr
Tires and Wheels
Apr 15, 2008 09:58 AM
lennyblazer
Tires and Wheels
14
Sep 27, 2007 06:55 PM
