Must I lift?
Old Dec 10, 2007 | 02:48 PM
basketballmail2's Avatar
basketballmail2 is an unknown quantity at this point
Default Must I lift?
Alright guys I decided to get myself a hunter brushguard for my truck, now my question is will I have to lift the front of the truck when I have it mounted to level it back out? I read about cranking the torsion bars, but I never have done such a thing, plus I've read that it isn't good for your ball joints etc. Any input on this would be great.
Thanks
Cedric
Old Dec 10, 2007 | 02:55 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: Must I lift?
brushguard should'nt change anything with how your truck is sitting.
Old Dec 10, 2007 | 03:10 PM
nj4x4blaze's Avatar
Agreed.
Old Dec 10, 2007 | 03:33 PM
mdehoogh's Avatar
i would think the extra weight would compress the suspension a little bit... similar to when you're not in your truck and then when you get in, it moves down a little bit.
i dont know exactly how much a brushguard weighs so i dont know how much it would affect the truck
Old Dec 10, 2007 | 04:39 PM
Cool, thanks guys
Old Dec 10, 2007 | 06:34 PM
drperry's Avatar
I know mine sank down a touch when I put the guard on...
My 30s rub a little bit now, lol.
I'm pretty sure I sank less than 1/4" though.
If you're running factory sized rubber, you won't have any issues at all.
Old Dec 10, 2007 | 06:41 PM
yep totally stock Just placed my order, can hardly wait
Old Dec 10, 2007 | 07:18 PM
drperry's Avatar
Make sure to post up pics!
Old Dec 15, 2007 | 06:47 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
ive got 30's and the hunter guard... it weighs around 90 lbs..... I have no issues with anything, no rubbing, sagging, etc.... you will not have to lift, even with 30's... If your 30's are rubbing, your torsion bars may be beginning to show signs of wear and becoming weaker.... they need tightened and your truck needs realigned, or just have your truck realigned, because sagging will throw the alignment off a bit...
Old Dec 16, 2007 | 03:09 AM
drperry's Avatar
ORIGINAL: a_tack
Well, I do beat the **** out of it, so that's probably part if it, lol.
Saint
Tires and Wheels
Sep 28, 2008 04:41 PM
chipjumper
Jul 27, 2008 10:28 PM
Tippman7641
Jul 2, 2008 09:53 AM
thevair65
Jul 8, 2007 10:39 AM
swartlkk
Aug 27, 2006 11:35 PM
