My 2" shackle lift
Old Feb 14, 2010 | 09:06 PM
  #51
BlaziNator's Avatar
BlaziNator is on a distinguished road
Originally Posted by bigdaddykane93
yeah these are the shackles i was asking you to measure centerline to centerline. it can still be done with the bolts in it. just measured center to center on the bolts. and also you mean those pro comp shocks are not hard to extend apart?
They look like 6 1/2 inches from center to center. The shocks are equally hard to compress as they are to extend.
Old Feb 15, 2010 | 09:48 AM
  #52
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
so they are only 2 1/2" longer center to center than the stock shackles? my stock shackles measure 4" apart center to center. and howmuch lift did you get with the extra 2 1/2" of height in the shackles?
on the rear shocks, if you compress them and then just let go of them, will they stay compressed? or will they want to extend back up on there own?
thanks so much
Old Feb 15, 2010 | 05:12 PM
  #53
BlaziNator's Avatar
I want to say I got a solid 1 and 3/4 inches of actual lift...I measured before and after, but I totally forgot what the numbers were. I want to say I posted them on the forum somewhere...dunno. The shocks stay compressed.
Old Feb 21, 2010 | 11:40 PM
  #54
<3blazer's Avatar
<3blazer is on a distinguished road
I already put add a leafs and torsion keys in my car to get rid of its sag, but now i want an additional 2 inches on top of that, will it work if i put shackles in and crank the t bars?
Old Feb 22, 2010 | 12:55 AM
  #55
BlaziNator's Avatar
It....should...depending on how much more you can crank the torsion bars. You will play havoc on your CV Axles and Ball Joints though...
Old Feb 22, 2010 | 04:31 PM
  #56
BlaziNator's Avatar
I FINALLY got the correct front shocks in for both the blazers...should be installing them this weekend =D
Old Feb 22, 2010 | 05:28 PM
  #57
cquinn009's Avatar
cquinn009 is on a distinguished road
are shackles hard to put on and do you have to put them on the front too?? i would love to do this to my blazer but idk what i would need? thanks
p.s. looks sick man
Old Feb 22, 2010 | 06:36 PM
  #58
BlaziNator's Avatar
The actual process of putting them on is fairly straight forward. It only involves removing and reinstalling 4 bolts (6 if you include the shock mounts) The trouble is that most of those bolts are usually frozen with rust and grime. Especially if you live in a Northern area where they salt the roads. I had a tire shop change out my wifes for $100. Well worth it in my book. Mine took FOREVER and broke a few tools in the process. The shackles are only used on the rear suspension (leaf springs). Up front you have independent front suspension sprung by torsion bars. No shackles involved. In order to lift the front you crank the torsion bars. Which is REALLY easy to do, but requires an alignment afterward. You can find a how-to on here I'm pretty sure with a little searching. Good luck and ask any other questions you have. Thanks BTW =)
Old Feb 22, 2010 | 08:11 PM
  #59
<3blazer's Avatar
hmm so i probably shouldnt? how can i get more of a lift besides a BL?
Old Feb 22, 2010 | 09:05 PM
  #60
BlaziNator's Avatar
Well, the general consensus is that 1.5 - 2" of lift from the torsion bars is manageable. Anything over that will cause problems like I stated. There are a few lift kits floating around out there:
http://www.sfxperformance.com/parts/...its/page_1.htm
http://www.cardomain.com/ride/685810
