not your normal tbar question
next month sometime im goina get my lower ball joints replace i was wonderin if should have them crank my tbars up maybe about 1.5" higher then stock and get some shocks and shackles or would that be a bad idea? and do you think that the mechanics would crank them higher?
jimmyboy
jimmyboy
i know that but i didnt know how soon it would need replacin. do you think that my westin push bar will be able to go up with a body lift? i know that with the body lifts they have the bumper adapters to make it macth up with the body but my push bar be moved up with no problems?
jimmyboy
jimmyboy
The westin push bars use nearly idential mounts to the hunters (if my understanding is correct), all you need to do is is when you put the lift bracket for the front bumper on, line it up with the lower support to the push bars. From here mark the holes that you need to drill and drill new holes to hold the lower support. From there use hardware from the kit and bolt it on.
NT_Hardcore
Apr 11, 2012 01:36 PM
