not your normal tbar question
Old Oct 21, 2007 | 04:39 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
Default not your normal tbar question
next month sometime im goina get my lower ball joints replace i was wonderin if should have them crank my tbars up maybe about 1.5" higher then stock and get some shocks and shackles or would that be a bad idea? and do you think that the mechanics would crank them higher?
jimmyboy
Old Oct 21, 2007 | 04:46 PM
rriddle3's Avatar
Default RE: not your normal tbar question
If you crank the torsion bars, you'll be replacing the ball joints again, only sooner. That puts stress on the suspension that it was not designed for.
Old Oct 21, 2007 | 04:57 PM
jimmyboy's Avatar
i know that but i didnt know how soon it would need replacin. do you think that my westin push bar will be able to go up with a body lift? i know that with the body lifts they have the bumper adapters to make it macth up with the body but my push bar be moved up with no problems?
jimmyboy
Old Oct 21, 2007 | 08:19 PM
mdehoogh's Avatar
well the pushbar should be mounted to the frame so i would think it will stay where its at. but im sure theres a way to move it up
Old Oct 21, 2007 | 08:58 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
I know that RCars2 has a Hunter brush guard and was able to change something or mount it differently. I would PM him and see what he did.
Old Oct 29, 2007 | 02:12 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
The westin push bars use nearly idential mounts to the hunters (if my understanding is correct), all you need to do is is when you put the lift bracket for the front bumper on, line it up with the lower support to the push bars. From here mark the holes that you need to drill and drill new holes to hold the lower support. From there use hardware from the kit and bolt it on.
ohsofly
Dec 5, 2013 09:41 PM
NT_Hardcore
Apr 11, 2012 01:36 PM
jpfencl
Oct 12, 2010 09:07 AM
SPLjimmy
Feb 10, 2010 11:38 AM
94blueknight
Suspension Tech
Mar 19, 2008 10:23 AM
