Parts Question
Please forgive me for my naivete but I am brand spanking new to the 4x4 scene.
I have a 1 1/2 inch lift on the front and 2 inch lift on the back of my 2001 Blazer. I need front sway bar bushings now and eventually front shocks on it.
My questions are
A) Will stock sway bar bushing kits work or do I need aftermarket?
B) I assume that stock shocks won't have the travel necessary to compensate for the lift. Any suggestions on them that won't break the bank?
The truck will be my daily driver but also for sand (with the occasional small rock) beach driving.
Thanks in advance.
My questions are
Thanks in advance.
1) The stock sway bar bushings will work. You might tear them up quickly depending on how your front end wears and how maxed out it is. That's just the nature of a torsion bar crank on the blazers. But to fix this you need a lot more than an upgraded bushing/link kit.
2) I believe that with that much lift you're going to need longer shocks. The stock ones will work in most circumstances, but you could run into trouble. If you're looking for cheaper shocks check out the ones that superlift or rough country sell to go with their lift kits. For that, give these guys a call www.rockymountainsusp.com. They usually have better prices on the phone than on the site. If you're looking for a really good shock, then find a Bilstein that meets the spec of what you need. Bilsteins will be closer to breaking the bank.
I'm not familiar with this area, but you may want to actually disconnect your sway bars. It will give you better flex and less hop when going over mounds/bumps. That of course is only advice for off road. Sway bars are more for handling performance when going around turns at speeed, not low speed off-roading.
I did a little research and found the KYB mono max. THey may be a little stiffer than a normal shock but I do get a little tire rub on the back side of the front fender over decent bumps. I think these shocks may just limit this a bit. This project gets under way as soon as I can get both of my axles done.
I did go with the Moog sway bar links. They go on tomorrow along with the right side axle.
I was out on Burma road in my buddies truck last night. That road is torn the heck up. Too many morons who don't air down especially after the last holiday weekend.
If you're talking about the lower part of the fender and it's while you're turning, you may want to trim the fender a little or at least bend up the corner. Some people with the stock 235/75/15s complain they get slight rubbing there.
Nah I trimmed that front and back a while ago. Its if your hit a nice bump on the beach or have some weight the suspension will flex and my tire will hit the top or the fender and rub. Its not on the corners or front or back at all. I trimmed those back a good 2"s :-) Oh and yeah my tbars are even cranked up
1996BlazerSD605
Jul 16, 2011 09:47 PM
lionel2
17
Feb 13, 2008 04:23 PM
