Problem Leveling Suspension after 2.5" RC Lift Kit - 89 S10 Blazer 4x4
Old Dec 18, 2018 | 06:28 PM
bhorn's Avatar
bhorn is on a distinguished road
Default Problem Leveling Suspension after 2.5" RC Lift Kit - 89 S10 Blazer 4x4
Hey guys, I'm having a problem with my torsion bar adjustment and wanted to see if someone might be able to help. My front end is over 1" higher than the rear, but I cannot go any lower up front. The t-bar bolts are just tightened enough to engage the key, but it's still much higher than the rear. I'm also having an issue with the CV boots rubbing on the shocks, and after calling Rough Country to ask what the issue may be, they told me I probably have the front lifted too high. I can't go any lower to get to where my car is level and my CV boots don't rub.
Could I have work/sagging torsion bars? I assume that if that's the problem, I would have the opposite symptoms, and my front end would be too low, but I don't know what typically happens when they go bad (This is my first time doing work on a suspension with torsion bars so I don't know what to look for in replacing them). The new torsion keys that came with the kit are installed, my only other thought is that I could rotate the keys on the torsion bars 1/6 rotation (since they have a hex shaped hole), but I am pretty positive that they are supposed to mate up easily. Thanks for reading!
Old Dec 18, 2018 | 07:52 PM
I would go with re- alignment of the torsion keys, it sounds like they might be off one. I could be wrong. Did you mark where the stock ones sat when you pulled them off?
Old Dec 19, 2018 | 09:10 PM
I agree with DonL that it sounds like you are off by one sixth of the turn on the new torsion bar keys.
uhlhazard
Oct 20, 2016 03:16 PM
ckroll98
Lifting Tech
Oct 17, 2013 09:55 AM
blazin 4.3
Lifting Tech
Sep 29, 2008 03:19 PM
Eric0072
Lifting Tech
Aug 19, 2008 08:19 PM
tkebillybob
Jan 16, 2008 06:45 PM
