question about a lift.
Old Sep 27, 2009 | 08:39 PM
akbogger's Avatar
akbogger is on a distinguished road
Default question about a lift.
what is the difference of a rear block rather than a rear spring? please get back anyone. thanks
Old Sep 28, 2009 | 06:08 AM
In what context are you referring? For lifting a vehicle such as the s-series trucks, a block will not work. The spring is under the axle so a block would lower the back of the truck. When someone installs lift springs, they generally have more arch to them which creates more lift. If the spring were over the axle (swapping it will net about 5" lift without doing anything else), then blocks will lift the vehicle by however thick the blocks are. The problem with blocks is they allow more axle wrap which can be a bad thing.
Old Sep 28, 2009 | 07:22 PM
akbogger's Avatar
well it is for a 77' k5 blazer. and im putting a 4 inch lift on it. i am just wondering if it it worth the extra $500 to go with springs instead of blocks.
Old Sep 28, 2009 | 07:48 PM
Most definitely. Especially if you want to drive and wheel it.
Old Sep 29, 2009 | 07:27 PM
akbogger's Avatar
okay i'll get the springs. thank you very much swartlkk
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
