Rough country 2.5"
yeah the key is the same size, just indexed a little differently.
I'm running out of ideas, how far in is the bolt? Are you sure the weight is being supported by the torsion bars? It's not being supported by the bump stops?
I know its being held by torsion bars because i never put the bump stops in. Forgot them. I dont even know how i would fix it if they weren't being supported by the torsion bars. The bolts can be taken all the way up with minimal adjustment
Without seeing it in person I don't know what else to suggest. Maybe you should take a bunch of pictures of everything and post them up.
The adjuster bolt, the torsion bar in the control are, the upper and lower control arms etc, you never know. Someone might see something.
I was finally able to get it cranked to 22.5" on one side and just under that on the passenger. How far up can i run the adjustment bolts? I havent maxed them out yet but dont want to if it would be unsafe/bad for my car. Ill post some pics when I get home.
