Rubbing tires
Old Aug 1, 2009 | 05:25 PM
mav06's Avatar
mav06 is on a distinguished road
Default Rubbing tires
I have a 2000 Blazer, with i think eagle alloy rims, and p235/75/15 tires on them. So kinda a long story of how i got those tires. It was my mistake and i read my tires size wrong and yeah so i have those tires now. The Problem is that they rub in the front when i turn or if i hit to hard in the front. So what would be your suggestions? I have heard people say that these tires shouldn't be rubbing. I mean i had p235/70/15 and went a little skinner tire to a p235/75/15 and they rub kinda surprising. what would you suggest? torsion bars? Lift Kit? New tires? Thanks for the help.
Old Aug 1, 2009 | 05:28 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
what are the specs of your rims?? to stop the rubbing you can either trim, buy new tires, go back to your stock rims or crank your tbars a bit.
Old Aug 1, 2009 | 05:36 PM
bandidolenny's Avatar
Do you have factory rims?
Crank the torsion bar adjuster bolts about 4 or 5 turns each for about a 1" lift in the front.
Old Aug 1, 2009 | 07:22 PM
mav06's Avatar
Umm if i crank up the torsion bars would it mess up my ride some? Like how smooth the ride would be? Would i have to get it realigned? How would i find out the specifics of the Rims?
Thanks for the help i love these forms.
matt
Old Aug 1, 2009 | 07:35 PM
mikeinwi's Avatar
cranking your tbars an inch wont really affect much as far as ride quality is concerned, but you will need an alignment afterwards.
Old Aug 16, 2009 | 06:29 PM
Swain's Avatar
Swain is an unknown quantity at this point
Cranking your Tbars will affect your ride quality, 1" wont be AS bad but anything more and your front suspension will be more of a springboard then suspension. Ask me how I know, but in your case you pretty much are stuck with going back to your stock rims(or tires), cutting fender(last resort), small Tbar lift, or a body lift.
butta25
Tires and Wheels
May 26, 2014 01:18 PM
PaulO2288
Tires and Wheels
14
May 11, 2010 02:31 PM
ZeroShade0
Jan 8, 2008 10:12 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
DrkJrny
Jan 17, 2007 10:12 PM
