Set of Interco 33" 12.5 /15 for $150!
A friend of mine is selling me a used set of Interco TrXus M/T 33" 12.5 /15 for $150, which is a good price for these tires here in Lebanon compared to new ones, and they're like 80 to 85% new
I have a 2 doors 1989 S10 Blazer Sport 4WD 4.3L TBI 6Cyl. I'm planing to crank the TB and add 2" shackles, no body lift, and want to keep the stock rims
. What will I need to do to fit these Interco? I don't mind trimming and bending things, or even fabricating easy metal sheets stuff for wheel wells or else. I know I'll end-up trimming a lot, but what should I start with after TB and shackles? One more thing; Will I need longer shocks after that 2" lift?
I would try and get a body lift if you can. You can buy the blocks separately if you want to try and piece it out cheaper than a full kit.
Your wheels will probably create issues as well. They may rub the frame and/or swaybar which can't be fixed by trimming. Lower offset wheels would push them away from the car where the only rubbing is on the fender/bumper which is easily cut.
Shocks would be a good idea esp if you'll be going offroad at all. The stock shocks can only extend so far and will stop the suspension from flexing as far as it can
Good luck, that's an awesome deal on the tires
Well your going to have to trim a lot of metal. And with stock rims and a 12.50 tire you will probably need spacers to keep from hitting the sway bar or frame which will mean more trimming to the fenders with that it should be doable
Regarding my shocks, yes I want to go offroading!
What shocks do you recommend? Is there a stock (OEM) one off another truck or make that I can use? (Tahoe, 2nd gen. Blazer, ZR2, Toyota, Jeep...) It's not easy to find custom shocks here. And if I keep my shocks, how much stretch will I lose when flexing? And is it the same issue for the front and rear?Thanks for your quick replies guys!
Wheels with lower offset/backspacing or spacers like Nismo mentioned, will push the wheels position further away from the truck. That way, when you turn the wheel, the tires won't hit the frame. Instead they will hit the outer fender but you can trim the outer fender easily and you can't with the frame
I'll fix the title so it says 33"
i'm just going by what James did in his build, found HERE.
i don't remember seeing him install them anyways.
i'm not a big fan of any BL's, but if it meant i could slip some 33's on my rig, then i'd be up to @ least try it and see.
i had 31's on a couple of my 1st gen trucks-without any t-bar crank or shackles-so you should be able to fit 33's on there with a t-bar tweek, some shackles, and a BL kit.
shouldn't need any more than 2 or 3 inches on the BL.
