Shackle removal
Old Feb 19, 2008 | 12:05 PM
mccague36's Avatar
mccague36 is an unknown quantity at this point
Default Shackle removal
Well, I have the front of my blazer lifted almost 2 inches and I am in the process of lifting the rear. I just bought 2" shackles and I was wondering how to install them. Besides the obvious, put the back end on jack stands and floor jack under the differential, are there any other precautions I should be taking? Right now my plan is to lift the back off the ground and start wrenching off the shackle bolts then put the new ones up, but should i be worried about the energy in the leaf springs or shocks shooting out? I am no mechanic, but I am pretty mechanically inclined. Any advice will help and be appreciated. Thank you.
And if it means anything, its a 98 4 door with 4wd.
Old Feb 19, 2008 | 12:54 PM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
Default RE: Shackle removal
you should have to worry too much about the spring coming back up, but it is difficult to pull them down, so I just put a jack on top of the spring and jacked it down to get the longer shackels in. other than that soak the crap out of the bolts with some wd or pb blaster, u might have a hard time getting them out of the metal bushing sleeves. I had to cut out my bushings and get new ones, luckly I had a spare set from a XJ lift I did.
Old Feb 19, 2008 | 02:04 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Be very carefull with the springs! Take the load off the springs! They will shoot up with enough recoil to do serious damage to your truck or you!
Not something to take lightly!
Here is an install thread
Shackle Install
If your still confused, I strongly recommed paying someone to do it.
Old Feb 19, 2008 | 03:46 PM
mccague36's Avatar
thanks for the advice, i think i have to tools and the know how, i guess we'll see.
Old Feb 20, 2008 | 01:39 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
its not as bad as it may sound, it is a very simple process with some sort of mechanical skill.
Old Feb 20, 2008 | 03:54 PM
navyblue_sk8er's Avatar
navyblue_sk8er is an unknown quantity at this point
If the rear end is on jack stands then you have nothing to worry about.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
uncle larrys oranges
Lifting Tech
Feb 1, 2010 12:18 AM
jason1978
Nov 10, 2009 01:02 AM
flyinbrad
Suspension Tech
Jan 20, 2009 01:23 AM
vermillion2
Jun 15, 2007 10:24 AM
