Shackle trouble....
Old Jan 26, 2013 | 09:58 AM
abig84's Avatar
Originally Posted by coolasice
a ball joint press will pop those babies out no problem...
thats a good idea ill try that next time. my normal method that i do at work, i usually do these on the drive on lift, but ill cut the bolts if they wont come out, ratchet strap the leaf spring down as low as i can get it onto the lift, set the bushing on fire then air hammer the rubber and center sleave out of the leaf spring, then using a flat blade on the air hammer to smack out the outter sleeve. it only takes like 5-10 minutes to do all that but thats of course at a shop with a lift and every tool you can think of
Old Jan 26, 2013 | 10:19 AM
newguy's Avatar
What about the heat and wax trick?
Old Jan 26, 2013 | 10:36 AM
okiedoak20's Avatar
i ended up saw alling the bolts off then using a method found here on this site, using a drill bit and drilling out the rubber from the bushing, then removing the old bushing and replacing the bolt and nut, its a PITA, but i sure do like the new urethane bushings, i also coated every thing well in grease, so the problem wont happen again..
Old Jan 26, 2013 | 11:15 AM
matt9589's Avatar
matt9589 is on a distinguished road
Originally Posted by neo71665
Now that I own one that's the only way to do it. Not everybody is as well stocked with tools. When their DD/only ride is tore down sitting in the yard at a stuck point suggesting a tool they don't have and can't go get is like pouring salt in an open wound.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
Tommyboy8299
Lifting Tech
Jan 26, 2013 10:39 AM
DreezyBeezy
Lifting Tech
May 27, 2012 01:11 AM
Wisco Blazer
Lifting Tech
Apr 29, 2012 11:43 PM
vermillion2
Jun 15, 2007 10:24 AM
