Shackle install trouble
Old May 25, 2012 | 07:29 PM
DreezyBeezy's Avatar
DreezyBeezy is on a distinguished road
Default Shackle install trouble
So i recently made up some lift shackles for my 99 LT 4dr, which are 8" from hole to hole. I had a hell of a time getting the stock ones off
my problem now, I have the 2" lift shackles mounted up at the top, how are you guys getting the spring down far enough to bolt in?
ive tried prying, pulling etc. I cant get them down far enough to put a bolt through it???
thanks in advance from a new member!
Old May 25, 2012 | 08:49 PM
warthogdriver's Avatar
I used a small bottle jack.
i have also done it using blocks of wood between the frame and spring adding a block at a time and pounding it in to wedge the spring down.
either way...BE CAREFUL.
Old May 25, 2012 | 10:29 PM
redneck44244's Avatar
redneck44244 is on a distinguished road
i had the same problem with mine and i found that my shocks were holding the rear end up, i unbolted the shocks and then the rear end dropped enough to were i was able to bolt them right up with out prying them down.
Old May 26, 2012 | 10:17 AM
thanks for the helps guys! I ended up throwing a bottle jack in there and they slid right in!
I will start a build thread soon with some pictures, its come a long way from stock, and has a long way to go!
Old May 26, 2012 | 03:55 PM
xgiovannix12's Avatar
sounds like your shocks are 2 short you might wanna upgrade them soon
ride quality might change till then
Old May 26, 2012 | 05:10 PM
the shocks are stock, from what ive read they shouldnt be a problem. However they are not in the best shape, i will be replacing them with some rancho shocks soon, when the 31's go on.
Old May 26, 2012 | 08:11 PM
c_mcintosh's Avatar
c_mcintosh is on a distinguished road
yea same with mine, running with the 2/3 inch shackle lift, the shocks resist. looking for shocks soon or shock extensions. any ideas of good stuff?
Old May 27, 2012 | 01:11 AM
i had replaced mine right after i raised the rear with rancho shocks rs5000 and i really like them and they had plenty of extra length with the lift.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
Wisco Blazer
Lifting Tech
Apr 29, 2012 11:43 PM
btmbass
Lifting Tech
Sep 18, 2011 10:12 PM
Charder
Lifting Tech
May 26, 2011 07:26 PM
greenlantern77
Jun 12, 2008 05:06 PM
