shackles
Old Jul 24, 2009 | 10:58 PM
sk8indigomoon247's Avatar
sk8indigomoon247 is an unknown quantity at this point
Default shackles
ok i got my shackles today, i got a question. does anybody have any like pictures or any hints on the install?
Old Jul 26, 2009 | 11:03 AM
vermillion2's Avatar
vermillion2 is an unknown quantity at this point
it's really straight forward. Lift the back end up with a floorjack (put it under the differential with a block of wood so you don't have to worry about cracking it) then put jackstands under the frame infront of the rear tires before where the leafspring bolts into the frame. Then just unbolt the stock shackles. Use alot of PB Blaster or WD40 on the bolts. Then just swap in the new shackles, bolt everything back up nice and tight and youre done. It took me a couple of hours to do mine, but that was just because one bolt was seized in there pretty good. Just bang on it back and forth with a big hammer and it broke free.
Here's what you're looking for though.
http://www.zr2usa.com/mboard/index.php?showtopic=14200
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
