Shocks for Lifted Trucks
Old Mar 20, 2012 | 02:15 AM
tibby's Avatar
Default Shocks for Lifted Trucks
Okay,
So right now I have a 2 inch body lift on the blaze. I know body lifts and shock lengths have nothing to do with each other. But I will probably eventually get more lift added on. Between 1.5 and 2.5 more inches (t-bar or rough country 2.5) is what I was looking at getting eventually. But yesterday I think my front right shock bottomed out and I heard it make a noise, kind of like a quick pop or crunch or something when I went over a pretty big bump. This bump is actually pretty huge and the blaze has its hind end up when the front nose dives over the bump. That's how big of a bump it is.
But anyways, I wanted to get some Rancho RS5000s but with a longer than stock shock length since I plan to lift eventually. Where do you get lifted shocks at? Or should I not worry about getting lifted shocks and go with stock height Rancho's? Because according to Rancho's website, they only have shocks for stock height blazers. Any help on this issue?
Old Mar 20, 2012 | 09:23 AM
99LS4x4ryanlw's Avatar
99LS4x4ryanlw is on a distinguished road
I would say with the RS5000's you should be just fine. I got a long AAL for mine and a t-bar crank in the front, and my rear end sits much higher than the front (see sig), a lot more than I would like anyway. The AAL gave me around a 2 or 2.5" lift in the back and the Rancho's hold up just fine with no problems from what I can see. Personally I would say go for it from my experience, but I certainly wouldn't want to test the waters with any more lift than 2.5" on those 5000's IMO
Old Mar 20, 2012 | 01:11 PM
tibby's Avatar
Default .
That's what I'm worried about though. I need some travel in the shock when I go offroading. And when I end up getting another lift eventually and then take it offroading, probably won't have much room for the shocks to travel.
Old Mar 20, 2012 | 03:44 PM
I can't say for sure about the travel, but the bump you described in your first post is about the same as one of the bumps that I run across every day going to class with no problems, but that's kinda like comparing apples to oranges when it comes to off-roading though. I would say from what I can tell there shouldn't be much trouble, but you are probably better off safe than sorry when it comes to the Rancho's and see what else you could find...
Old Mar 20, 2012 | 04:42 PM
xgiovannix12's Avatar
Im looking into these
Pro Comp Suspension Systems 924509 - Pro Comp ES9000 Shocks - Overview - SummitRacing.com
they are made for the 2 inch suspension lift
Old Mar 20, 2012 | 04:55 PM
tibby's Avatar
Default .
I've done more research since posting and am almost set on Monroe Reflex shocks. They are a combo between stiff when you offroad and smooth on the highway. I was looking at the Rancho 5000s for the longest time, but heard the ride was stiff all the time. I think the Monroe Reflex shocks are my best bet. =P
I may hold off on getting longer shocks now if I get these. I didn't plan on getting a ifs lift for a little while anyway. I'll update yall later on what I do, but most likely the Monroe Reflex is what I'll get.
nj4x4blaze
Sep 11, 2020 12:19 PM
newguy
Jan 27, 2014 09:02 PM
Blazer51
Suspension Tech
Feb 2, 2013 03:51 AM
50lb_cat
Aug 25, 2012 10:05 AM
flipzat
Feb 25, 2010 12:13 AM
