Spring spacers?
Old Aug 10, 2012 | 10:52 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Default Spring spacers?
Will these add any noticable lift to my truck? also what are the dangers of using these?
Old Aug 10, 2012 | 11:12 PM
Rottidog's Avatar
On what, rear leafs? Year, make, model, 2wd, 4wd helps in ALL posts for help btw.
Usually when a persons ride has a saggy rear they do an Add-A-Leaf or replace/upgrade the leaf spring pack.
What spring spacers are you talking about? Shackles? Look them up in here, possibly 45,000 posts about shackles & t bar twists lol.
Lots to read & decide about on them.
Rear shackles are common to raise the rear & keep in mind that often a "2" shackle lift kit" only adds 1" of lift because it's only lifting half the rear leaf. To get 2" of true lift you'll need shackles that are 4" longer than stock.
Old Aug 10, 2012 | 11:45 PM
Jamaroon's Avatar
His profile says 2002 4 door 2wd. So I'm thinking he means coil spacers for the front.
Yes they will lift it, I can only assume it'll add some extra wear on a few of the front end components. I don't have any first hand experience with lifting a 2wd though.
Do some searching and I'm sure you'll find something on it in here.
Old Aug 11, 2012 | 12:29 AM
Rottidog's Avatar
I didn't look at profile but when I 1st saw "spring spacers" for some reason I thought coils. But I had to ask.
Old Aug 25, 2012 | 09:34 PM
fletch125's Avatar
What do you suggest i do? My rear end isnt sagging, the shocks and everything are newer. I just want a couple inches of lift without a full blown $400 lift kit.
twistedmetal
Feb 8, 2018 07:04 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
Rp9110
Lifting Tech
17
Feb 14, 2008 08:59 AM
nails5240
Tires and Wheels
Jun 14, 2006 12:38 AM
quontush
Apr 21, 2006 08:27 PM
