START HERE - lift kit list
Old Jan 25, 2010 | 04:50 PM
  #41
JRob238's Avatar
JRob238 is on a distinguished road
Originally Posted by 97blazer13
I don't know if this is a common problem or not, but I installed the Rough Country 2" lift and the new upper C/A's did not last long. The bolt holes rounded out and now nearly all of my brand new front suspension components are worthless... Has anyone else heard of or had this problem? I am thinking if I dont go higher I will have the local fabricating shop either repair them or make stronger copies. Any help would be appreciated.
Rough Country has done a lot of work to make their kits more reliable. Most all their kits from the years past had numerous problems. But now they have been getting exceptional reviews. I myself have owned both old and new RC kits and can say the quality of the new kits are far greater than previous years. I ran a 4.5" AAL kit on my XJ for over 2 years and never had a problem. The AAL's held up surprisingly well and stayed at 5" ride height until I sold the Jeep. As far as I know its still not sagging. I beat the crap out of that lift too. Trips all over the U.S. from Tellico to Moab. Rough Country never failed me once. Now the old kit I had sucked. First trip to Tellico I had to replace ball joints trac bar shock the whole 9 yards. They also have a better ride thanks to the 2.2 performance shock line they have out now. Beats the hell out of the old nitro 900's.
Old Jan 25, 2010 | 05:35 PM
  #42
JustinBurden's Avatar
JustinBurden is on a distinguished road
Default yea thats what im talking about sorry. 2nd gen i want the biggest tires i can fit on
are you talkin' about 285/70/R15's?
what truck do you have (1st or 2nd gen?)
either way, 4 inches will cover a 31" tire.
remember to supply the info for the application, when asking a question Justin.
yea thats what im talking about sorry. 2nd gen. I want the biggest tires i can fit on it .
Old Jan 26, 2010 | 05:45 AM
  #43
nj4x4blaze's Avatar
Originally Posted by JRob238
Ok so if I read this correctly then I will not need a SYE or transfer case drop with 4" of lift on my 97 2 door ls?
2" shackles and 2" body lift doesnt require you to drop your transfer case. The only time the transfer case gets lowered is when you do an actual 5" or 6" suspension lift.
Old Jan 26, 2010 | 05:50 AM
  #44
nj4x4blaze's Avatar
read the first post in this thread. It explains what tire size fits and what tire sizes require the fenders to be trimmed. And if you are confused as to what size a 285/70/15 tire is, then click on the tire calculator link below.
http://www.miata.net/garage/tirecalc.html
Note: I edited my post on the first page. Added some additional info as well.
Old Feb 20, 2010 | 10:26 PM
  #45
98gmcjimmyboy's Avatar
98gmcjimmyboy is on a distinguished road
Default Wheel Spacers?
I was thinking about puting a 5" trailmaster lift in my jimmy and Putting on some 33's. Would 2" wheel spacers help with rubbing? Thancks alot you guys are a BIG help.
Old Feb 21, 2010 | 10:08 AM
  #46
old skool luvr's Avatar
think of wheel spacers like adding a wider tire.
this moves the outside edge of the tire out (like a wider tire), thus making it come in contact with the outside lower corner of the fender, instead of going inside the wheel well.
i'm not sure if a 5" lift will be enough for 33's though. Dave up there (nj4x4blaze) has 6" SL & 2"BL on his truck with 33's, i'm sure he didn't just add a BL for fun though.
Old Feb 21, 2010 | 04:54 PM
  #47
nj4x4blaze's Avatar
^correct^..... Get ready to use that sawzall to make those 33's work. lol
Old Feb 27, 2010 | 10:57 AM
  #48
harryjoe21's Avatar
harryjoe21 is an unknown quantity at this point
Default 31x10.5x15
I am no expert by far but i did have 31in kumhos on stock rims on my 96 jimmy all I had to do was crank the torsion bars the only rubbing I got was when the wheel was totally turned left or right back was fine.
Old Mar 16, 2010 | 08:03 PM
  #49
Reizvoll88's Avatar
Reizvoll88 is an unknown quantity at this point
Hey guys im new to this whole lifting scene, always had sporty cars instead, anyways i have a 97 2 dr blazer lt and i wanna lift it but dont wanna spend too much money. ive read about the body lifts and torsion bars and so on...so if i have read everything right does it man if i do a 2 RC body lift and some rear shackles and crank the torsion bars am i lookint at around 4" lift total? i have 30 tires as of new on the stock height. Also how hard is it to do the torsion crank? im not a total newbie with cars but im also not a mechanic but can do alot. Also do i need to get an alignment if i do the torsion bars? any suggestions would be great. Also i was thinking about maybe swaping out my factory rims for a set of older 80-90 camaro rallys.. anyone have any problems with the offset since those are for a 2wd and mines a 4wd?
Old Mar 16, 2010 | 10:14 PM
  #50
sooooo many questions there Reizvoll.
ok, you already have 30" tall tires, is that correct? (wasn't really sure about that in your post there)
with 30's you don't even need to do any lift-provided you don't suffer from "Blazer saggy butt syndrome". if you do the t-bar/shackles with a 2" BL, you'll clear 31's easily, maybe 32's-but i'd check with Dave (nj4x4blaze) about that first. and it seems like a given in the previous discussions that you don't wanna max out the t-bars @ 2 inches, only go about 1.5 inches.
anytime you do any front end work, you should get an alignment done.
now if you're going to have 2WD rims-which is what those Camaro rims essentially are- you're definately gonna need to put some sort of lift on your truck, 'cause the wheels are now gonna stick out farther, and therefore, they're gonna come in contact with the bottom edges of the fenders now. think of it like adding a wider tire to your truck.
funny......you've been a member since Sept/08, and this is your first post. one of those silent guys in the corner i guess. (gotta watch out for those ones )
