Stock ride hieght of 95 blazer.....
Old Jun 14, 2010 | 07:28 PM
MikeRo's Avatar
MikeRo is on a distinguished road
Default Stock ride hieght of 95 blazer.....
I have been messing around with the Torsion bars trying to gain a few inches to accompany the bigger shackles in the back, the problem is that i am not the original owner and i know that the previous owner did something with the front suspension. Before i go too far can someone tell me what the standard ride height of the front end, any measurements would be good? thanks
Old Jun 21, 2010 | 11:54 AM
ZR2Daddy01's Avatar
ZR2Daddy01 is on a distinguished road
measuring the distance between the lower control arm bushing bolt center line ( at the back) and the lowest inward edge on the steering knuckle, factory spec for all 4wd from 87 to 96 is 4 13/16 inches. 2wd same years is 2 7/8 inches. I have a book with all specs, with pics of adjustment and measurement points, for every car made between 87 and 09 if you need any more measurements.
Old Jun 21, 2010 | 11:42 PM
MikeRo's Avatar
Thanks, tomorrow after work I'll be sure to check it out. If i need more or have questions I'll let you know
Old Oct 17, 2010 | 09:41 PM
widmer31's Avatar
widmer31 is on a distinguished road
97 S-10 Blazer 4WD Stock Ride Height? Did a forum search and all I came up with was this post covering 87-96. Thanks
Old Oct 18, 2010 | 06:57 AM
Stock Trim Height Measurements
Specifically applicable to the 98+ trucks, but should be good for all 2nd gens (95+).
mav06
Lifting Tech
Nov 10, 2010 09:04 PM
98jblaze
Mar 30, 2010 09:41 AM
Spectreblazer
Feb 13, 2010 04:59 PM
01Jimmy
Suspension Tech
Feb 14, 2009 12:56 AM
GregC5
Jan 8, 2009 10:50 AM
