tbar crank
Old Nov 3, 2008 | 04:20 PM
ncmudblazer's Avatar
ncmudblazer is an unknown quantity at this point
Default tbar crank
on a 97 blazer to turn the tbars is there some sort of key needed for this?
thanks guys. and i forgot to add the question of how many turns will i need to lift the truck 1 to 1.5 in?
Old Nov 3, 2008 | 05:29 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Default RE: tbar crank
No, just a normal wrench. Clockwise for lift, counterclockwise for dropping the front.
"Keys" are the parts that are connected to the tbar. When you turn the bolt, it presses on the key and that changes the tbar setting.
Old Nov 3, 2008 | 05:39 PM
mdehoogh's Avatar
That's the bolt you need to tighten. I used a paint pen to mark the bolt so I knew how many turns I had gone in case I ever wanted to return to stock.
Old Nov 3, 2008 | 06:53 PM
mysons95's Avatar
Here is a picture of what you will be looking at when you are laying under your truck.
bclhaezveyr
Lifting Tech
33
Feb 24, 2012 02:05 PM
Monkeyman
Nov 19, 2009 08:32 PM
sk8indigomoon247
Lifting Tech
Aug 19, 2009 10:45 AM
19jimmy99
Lifting Tech
Apr 2, 2009 05:51 AM
jdblazin
Lifting Tech
Nov 21, 2007 07:06 AM
