Tbar crank set back...advice?
Old Oct 18, 2011 | 04:21 PM
99LS4x4ryanlw's Avatar
99LS4x4ryanlw is on a distinguished road
Default Tbar crank set back...advice?
OK, so I just had an add a leaf put in the rear of my 99 Blazer and a tbar crank in the front, but since the crank the CV boots have slipped and have been throwing grease everywhere. My blazer is still in the shop and getting new CV axles and such, plus they are being ridiculous and lowering the front all the way back down to where it should be...so now the front will be A LOT lower than the rear. To make sure the new boots don't slip off what do you guys recommend? As I am going to crank the tbars back up some (just maybe not as much as before) to not have such a huge difference in height, I just don't want a repeat performance, if you will. Hose clamps? Zip ties? Something is better than nothing. Thanks
Old Oct 25, 2011 | 08:15 AM
caddylac's Avatar
caddylac is an unknown quantity at this point
Well when I cranked mine the boots fell off too, so I replaced the cv's and left the lift as it was and so far my boots still stay on. I have probably 10,000 miles on them now with the bars almost maxed
Old Oct 25, 2011 | 11:17 AM
xgiovannix12's Avatar
yea i dont think thell slip off with the new ones
Old Oct 25, 2011 | 09:43 PM
Awesome, thanks for the replies. I backed the front down around 5/8" just to make sure it wont happen (or at least to delay wear on the front end a little longer) rides much better too with the front lower and the tbars not so tight. I have a little bounce in the ride again instead of it being stiff as a freaking rock
bclhaezveyr
Lifting Tech
33
Feb 24, 2012 02:05 PM
Monkeyman
Nov 19, 2009 08:32 PM
19jimmy99
Lifting Tech
Apr 2, 2009 05:51 AM
ncmudblazer
Lifting Tech
Nov 3, 2008 06:53 PM
jdblazin
Lifting Tech
Nov 21, 2007 07:06 AM
