torsion bar issue
Old Aug 26, 2010 | 04:42 PM
huntersblaze's Avatar
huntersblaze is on a distinguished road
Default torsion bar issue
When I got the truck about three years ago the drivers side of the vehicle was sagging pretty bad, but thanks to this forum I found that the problem was the torsion bar and all I needed to do was crank it up and get an alignment. Just recently I decided to do a 1.5 inch shackle lift/ tbar crank. After I finally got the shackles on I went to crank the torsion bars only to find that the drivers side adjustment bolt only had three turns left in it. So I turned it back down and I am riding around with a funny looking rake at the moment. I'm looking at getting one from the junkyard and my question is should I just get one for the drivers side or should I get two to make it equal. Even if I find one that has the same spring rate as my current ones.
Old Aug 26, 2010 | 07:33 PM
Unless you verify the diameter, you should get them in pairs.
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
