Torsion Bar Problem
Old Aug 3, 2008 | 04:26 PM
Eric0072's Avatar
Eric0072 is an unknown quantity at this point
Default Torsion Bar Problem
I was planning on doing the standard t-bar crank and shackle lift on my blazer. I crawled under to take a look and found that the t-bar bolt on the passenger side can be adjusted, but the drivers side key is already maxed out and the key bolt is bottomed out. the blazer is at stock ride height and sitting level. Do I need to replace the tbar? is this a wear and tear issue or is it possible that its more serious?
Old Aug 3, 2008 | 05:29 PM
Default RE: Torsion Bar Problem
Sounds like the torsion bar on the driver side has weakened over time and someone has re-leveled the truck to compensate. If you want to lift it more, you would most likely have to either get lift keys or new torsion bars. If it were me, I would get new torsion bars.
Old Aug 5, 2008 | 08:21 PM
Eric0072's Avatar
does anyone know if the bars from a 4x4 regular cab s10 pickup are the same as the LT blazer's? I cant deem to find torsion bars for a blazer at any of my local parts stores or mail order catalouge, save for LMC who wants 270 per side.
Old Aug 19, 2008 | 05:16 PM
Eric0072's Avatar
im going to try pullin out the drivers side bar and rotating it 180* and reinstall it.
Old Aug 19, 2008 | 08:19 PM
What do you hope to accomplish with that?
02blazerkyle
Lifting Tech
Oct 26, 2013 05:21 PM
sputnik
Dec 15, 2012 11:42 PM
azzr2
Mar 25, 2012 04:19 PM
hateitorlikeit
Lifting Tech
Jun 9, 2011 10:08 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
