torsion bar question
Old Mar 21, 2010 | 06:35 PM
93blazernick87's Avatar
93blazernick87 is on a distinguished road
Default torsion bar question
i read the torsion bar tutorial and saw at the bottom where is said you could replace the torsion bars can i replace mine with any of them on the list or can i only go up a certain amount thanks for ur time. that is the list.
now that ive said that here is the list of bars gm made
Part Number Bar Dia. NOM Torque
LH 15956501 26.63mm 1052
RH 15956502 26.63mm 1052
LH 15956503 27.94mm 1276
RH 15956504 27.94mm 1276
LH 15956505 29.36mm 1450
RH 15956506 29.36mm 1646
LH 15956509 30.69mm 1883
RH 15956510 30.69mm 1883
LH 15956511 32.51mm 2305
RH 15956512 32.51mm 2305
Old Mar 22, 2010 | 04:54 PM
neo71665's Avatar
Yes and no
I think those parts numbers are for the 2nd gens (but some were the same as first gens). Its easier to get them out and in better shape from a 2nd gen anyways. You just have to grind down the lip on the one end to make it work on a first gen.
Sorry if you don't have a first gen, I'm guessing you do by the name (93/87)
azzr2
Mar 25, 2012 04:19 PM
mdehoogh
Suspension Tech
Dec 3, 2008 06:51 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
KenpoFish
Feb 5, 2008 08:38 AM
stevelknievel
Lifting Tech
Apr 23, 2007 12:57 PM
