Trailmaster lift NEED HELP ASAP!!!
Na... If you look at the last and second to last picture of the bug, you can see that the blazer body is acually still there. You can see the trunk and the firewall. It was a red blazer.. The VW body was just welded to the blazer body. So the lift kit wasn't touched. And there was no evidence of grinding on the lift.
So you don't know anyone that has this lift?
Hey would you mind posting some pictures after your done with the blazer lift? ive been seriously considering buying the trailmaster 5" for my blazer, i just wanna see how it looks and get some other opinions on it
Oh and a acquiantance of mine who had a blazer with a trailmaster lift is gonna stop by and look at the diff for me. I havn't been working on it much cause i didn't want to get it all together just to find the diff is crooked. Hopfully he can remember if his trucks diff hub was this close to that bracket. I'll let you know how i goes...
Thanks....
I email trailmaster over the weekend. Then Monday I called them up. They said they got my email and saw the pictures. He said he didn't know whats going on and he said he'll call me back in an hour or two. He didn't. That's understandable cause maybe he got busy, etc..
So I called Trailmaster again today. He said the Research and development department has the pictures and said theres definatly a problem and they're trying to figure out what the problem is. He said he'll call me back in an hour. He didn't Again! Well, I'm glad we both know and understand that there is a problem! (sarcasm)
There Is no way(from what I could tell) to adjust the angles of the diff. Can't move the Rear A-arm/Diff brackets up and down cause there's a bolt where the stock lower A-arm was that holds a drop bracket.
My truck has been sitting on jack stands for a couple weeks now because of this problem! I'm starting to get a little pissed. Especially since there is NO TURNING AROUND cause the stock brackets have been cut.
And again... If anyone has a 1st or 2nd gen blazer that has this trailmaster lift. I need Pictures!! lol
OK, Good news... I called up trailmaster again today, They said that the flange should be around a 1/4" from the bracket and the clearence is fine with my truck. So thats really good news.. Now about the yoke pointing slightly down.. He said i should loosen the brackets, put a jack under the yoke and retighten the brackets. Also putting a washer between the pass. side axle drop bracket and the stock axle bracket will help bring up the yoke..
If anyone is installing this lift and needs help/suggestions let me know...
Thanks to everyone who replied....
I was hoping that everything would get sorted out.
One question though, why is it gonna take longer to do the rear because of you wanting to swap gear sets? I'd drive it once or twice with larger tires and snap some pics before the gear swap if need be. It will suck mpg wise and be slow as all get out but still. Plus the gear install should only take about 2 hours, now setting the angles and all that is what take all your time. Plus if anything is wrong once you start tear down that just adds more time.
