Wanting to Lift Truck, Recommendations?
Old Mar 29, 2009 | 11:43 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Default Wanting to Lift Truck, Recommendations?
Guys,
I have a 97 Chevy Blazer (2 Door, 4WD) and as of right now I'm running 31's, with the T-Bar cranked up. Its not the right way, but thats how I bought it, so I stuck with it. Regardless of that, I'd like to do it the right way. What am I going to need to lift the truck to run 31's right? Right now my suspension is stiff, almost break your back stiff.. I figured replacing shocks would help, so I replaced all shocks with Monroe's. Besides me blathering on, what do I need exactly to raise my truck to run 31's the right way, without stiffening my suspension so much, and can you provide me links to said items? Please dumb it down for me, new to body lifts...
Thanks.
Old Mar 30, 2009 | 07:56 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Fabtech makes a 6in suspension lift, i will be doing a 5-6in suspension lift
http://www.autopartswarehouse.com/de...TS21015BK.html
Old Mar 30, 2009 | 08:45 AM
orangesonoma's Avatar
orangesonoma is an unknown quantity at this point
if you want to crank your bars back down do a 2 inch body lift and that will clear the 31s fine
check out synergy off-road
http://shop.synergyoffroad.com/produ...urceCode=epro1
here is a link to the body lift kit
Old Mar 30, 2009 | 05:14 PM
stevo's Avatar
stevo is an unknown quantity at this point
wow a six inch lift for under 1000?
here is the bds 2 in bl for your truck
http://www.bds-suspension.com/kits/9226
and here is the instructions
http://www.bds-suspension.com/pdfs/9226.pdf
Old Mar 31, 2009 | 11:51 AM
Big Blaze's Avatar
Big Blaze is an unknown quantity at this point
The Fabtech lift kit in the link is for a full size Blazer, or Tahoe. Don't you have an S-series?
redblaze00
Lifting Tech
May 3, 2010 01:23 PM
94NDTA
Suspension Tech
Jan 31, 2009 11:24 PM
davidstl25
Engine & Internal
Dec 18, 2008 08:26 PM
BlackBeast
Lifting Tech
Nov 29, 2008 01:06 PM
viper4559
Jun 7, 2007 06:18 AM
