Wanting To Lift
Old Nov 29, 2008 | 11:17 AM
BlackBeast's Avatar
BlackBeast is an unknown quantity at this point
Default Wanting To Lift
Can anybody tell me if this set up would be a good way of going to lift my Blazer.
Thanks
http://www.jcwhitney.com/TUFF-COUNTR...3409_10101.jcw
Old Nov 29, 2008 | 11:30 AM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default RE: Wanting To Lift
Read this thread: https://blazerforum.com/m_123415/tm.htm
Old Nov 29, 2008 | 11:42 AM
BlackBeast's Avatar
Thanks Millertime, in your opinion which do you think is the best bang for the buck?
Old Nov 29, 2008 | 12:54 PM
Well from what I read the 2" lifts are junk. They are basically glorified t-bar cranks. 2" Bl are nice if your just wanting to fit bigger tires, but a lot of people don't like the way the frame shows. As far as the 5"-6" lifts I heard the BDS is the nicest. It seems to be the easiest and theres no welding required. But I think its the most expensive. If you are wanting to go bigger than 6" you will have to look into a solid front axle. But there are no kits yet( www.3leaffab.com is in the process of making a bolt in kit) and they require a lot of fab work. So its just depends on what you want out of your truck.
Old Nov 29, 2008 | 01:06 PM
BlackBeast's Avatar
Well I already have 31's on it right now and I just want a little something more just to raise and make it look better in my opinion. I've read that the rough country lift is really worth money because all your doing in crank the tbars and replacing parts with new ones. I don't really want to spend 2 grand on theBDS or any liftfor that matter really, just something settle and nice.I don't mind the way it looks after abody lift. All in all I just want to do something with it to raise it up without having the doubt that my bj's will go bad within a few thousand miles (meaning just cranking the tbars). I've already done that but I want something more.
danmiranda
Lifting Tech
Mar 31, 2009 11:51 AM
94NDTA
Suspension Tech
Jan 31, 2009 11:24 PM
cowboy717
Lifting Tech
Aug 22, 2007 11:33 PM
savage
May 14, 2007 08:16 PM
