Why dont they make a lift...
Old 03-27-2008, 10:42 PM
98BlazerLT4x4's Avatar
98BlazerLT4x4 is an unknown quantity at this point
Default Why dont they make a lift...
That has longer top and bottom control arms and longer axle shafts, so tweaking the torsion bars wouldn't kill the cv angles and you would get a wider stance??
Old 03-27-2008, 11:15 PM
navyblue_sk8er is an unknown quantity at this point
Default RE: Why dont they make a lift...
Isn't that what they did with the ZR2?
Old 03-27-2008, 11:24 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
ORIGINAL: navyblue_sk8er
haha... kind of...
the 5-6 inch lift doesnt kill your tb's.... it lowers them along with the front diff..
Old 03-27-2008, 11:59 PM
Why would you lower your diff when what I said earlier can do the same thing but you can keep your diff outta harms way?
Old 03-28-2008, 12:09 AM
a_tack's Avatar
i didnt say you need to... just said thats the only way your gonna retain any stock front end angles...lol I agree they should make more truck friendly lifts
Old 03-28-2008, 10:29 AM
WolfPack's Avatar
I wish they had a long arm kit as well. Jeeps get all the fun stuff...I just want better travel with less spine misalignment
Old 03-28-2008, 10:42 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
ORIGINAL: 98BlazerLT4x4
Because cranking the torsion bars makes the ride stiffer. Cranking them past the allowable 1.5" that you can stock (which is where the cv and ball joint angle problems come into effect), would give you a HORRIBLE ride and nobody would buy the kit.
Old 03-28-2008, 02:36 PM
Maybe a kit could include upper and lower control arms, axles, and torsion bars designed to be lifted. Seems that would be better than a $2000 kit that just drops the suspension.
Old 03-28-2008, 02:57 PM
Jigg's Avatar
It'd be a lot more than $2000...
Old 03-28-2008, 06:49 PM
WolfPack's Avatar
Haha yea...might as well buy a new vehicle for that. You're talking an entirely different suspension system...
Quick Reply: Why dont they make a lift...
