02 Blazer turn signal blinking fast
Old Jun 24, 2015 | 09:09 AM
ablank37821's Avatar
ablank37821 is on a distinguished road
Default 02 Blazer turn signal blinking fast
So the passenger side turn signal is in double time but only when the headlights are on, when off the turn signal functions normally. All my bulbs have been changed except the high beams which both still work. Another present issue is the battery voltage gauge fluctuating with both turn signals. Hopefully you guys have some insight because automotive electrical systems are not my specialty to say the least.
Old Jun 24, 2015 | 07:15 PM
Turn parking lights and 4 ways on. Watch the bulbs: If one is blinking the opposite as it should, look for a bad socket, (bad ground in the socket). Front side markers are supposed to flash opposite of turn signals.
Old Jun 25, 2015 | 10:28 PM
Alright after doing this I noticed that the side markers and turn signals were alternating as they should, but the passenger side blinker is only getting about half as bright as the driver side. They are brand new bulbs so age isn't a factor, would you say this point to a bad socket or ground?
Old Jun 26, 2015 | 08:10 AM
Good job! Yup, probably a bad ground in the socket, or where it grounds to the body.
Old Sep 15, 2021 | 02:21 PM
Denis Castilloux's Avatar
Denis Castilloux is on a distinguished road
Hi, i do know it's and old thread, for me it's a new problem. Same problem as "ablank37821" Led bulb all around with capacitor. It use to work correctly, i did check all the ground. Brightness is all equal .Please i need help
Thanks in advance
Old Sep 15, 2021 | 03:10 PM
It actually turned out to be the actual flasher behind the glove box for me
Old Sep 15, 2021 | 03:20 PM
Thanks it's probably the only thing i did not look at!
Old Sep 15, 2021 | 06:32 PM
I was not expecting an answer on a 6 year old thread! Lol
Glad your still around! How's the blazer running?
Old Sep 15, 2021 | 10:49 PM
221k miles and still going, but needs some tlc lol
Old Sep 16, 2021 | 02:20 PM
Amazing! Well glad your still around lurking the forum! Lol
BigEffingHammer
Jul 18, 2012 10:32 PM
lionel2
Sep 19, 2009 04:14 PM
mrmack070
Jul 27, 2009 09:05 AM
KHARDA
Nov 21, 2008 03:37 PM
scottvwcars
Dec 29, 2006 08:46 PM
