1989 Blazer Wipers
Old Nov 21, 2018 | 10:56 AM
goaler29's Avatar
goaler29 is on a distinguished road
Default 1989 Blazer Wipers
Just got S-10 Blazer 4X4 4.3L and wipers have started to behave erratically - when they do anything at all.
When I first turned on wipers, blades went all the way to top of arc - and stayed there.
After I drove a few miles, noticed some slow downward movement and a gradual return to normal sweep.
Next time I tried wipers, same result.
Pulled plug and cleaned terminals with dielectric grease.
Yesterday experienced same problem and local mechanic told me it sounded like I had moisture in wiper control box.
Took box cover off this morning and blew hot air onto circuit board. No change.
Pulled circuit board and found no obvious moisture. Put dielectric on connection prongs,
Turned wipers on, but no movement.
Power is going to motor because mist unit works.
Is the motor or circuit board just plain shot?
Would appreciate any comments or suggestions. Thanks.
Old Nov 21, 2018 | 01:44 PM
go chevy's Avatar
I had a similar problem with my 98 Blazer 4x4. My wipers worked when they wanted... I found by replacing the wiper pulse board, which I found on youtube videos, fixed the problem, they work like new now. The part was not expensive, want too say $25/$30 bucks and I fixed it myself, pretty simple... Hope this might help.
Old Nov 21, 2018 | 01:52 PM
If you already own a decent soldering iron, you could reflow the solder joints for free as shown in THIS THREAD I created quite a while ago.
Old Nov 21, 2018 | 02:18 PM
goaler29's Avatar
Thanks very much for taking the time. Seems like the board is likely culprit, as I've found similar wiper posts and that was approach they used. Found board for $34 shipped, but will also see if I can solder the original board as a backup. Was pretty easy to take apart, so hopefully a simple solution. These forums are great resources.
Old Nov 24, 2018 | 10:33 AM
go chevy's Avatar
I agree, this forum is a blessing! I forgot too mention earlier that I bought a new turn signal switch before I found out about the wiper pulse board. It wasn't the turn signal switch obviously but it did fix my cruise control which was not working when I bought the vehicle... A little pricy though, $160 bucks from AutoZone if I remember correctly.
Old Nov 26, 2018 | 01:35 PM
goaler29's Avatar
Just received new Dorman wiper circuit board, but unfortunately that didn't solve the problem. May well be the wiper motor, switch or both.
Thanks for reply. Any other comments welcomed.
Chevy#
Jul 20, 2015 10:44 AM
TZFBird
Mar 7, 2015 06:13 PM
JcP
Sep 10, 2012 04:10 PM
EEZ
Apr 23, 2011 11:57 PM
Unlimitedsp
Headers, Intake, & Exhaust
20
Jun 29, 2010 08:12 PM
