1993 GMC jimmy S15 rear defroster
Old Jan 15, 2012 | 07:13 PM
richphotos's Avatar
Default 1993 GMC jimmy S15 rear defroster
On my 1993 Jimmy (I had this SAME problem on my '94 blazer)
As you know, the rear defroster wire attaches to the base of the strong arm for the rear window, and then sends current through the strong arm to the defrosters on the glass. Well the little metal bracket on the strong arm broke, and I am not sure how to fix this. Someone said solder it, But I also read somewhere that there is some kind of putty that can be used.
Why the heck did GM decide to attach the wire for the defrost to the strong arm for the rear window, that is a terrible location!
I can get a photo of what I am talking about tomorrow.
*edit*
To be clear, its not the wire that attaches to the glass, its the wire that attaches to the strut. Seems like this is a pretty common problems. because of this design flaw
Old Jan 16, 2012 | 09:55 PM
blazer_grl's Avatar
blazer_grl is on a distinguished road
I know exactly what you're talking about. I have the same problem currently but I haven't gotten around to taking care of it. I too am curious as to how to fix this problem. >.>
Old Jan 17, 2012 | 10:19 AM
richphotos's Avatar
Its all too common! I already said this, but their design on this is just a terrible idea. I use the back of my truck a lot, So I am opening the glass a lot, so I can see this being a "regular" thing to fix until summer when I do not need the rear def
I hope someone is able to help!
Old Jan 17, 2012 | 10:26 AM
A lot of vehicles pass current through the lift support. I wouldn't call it a design flaw. You are dealing with an almost 20 year old vehicle. It is somewhat irrational to expect everything to last in perpetuity.
As far as fixing it, it really depends on where it came off of, but I would try soldering it first. Just don't go heating up the shock too much or it could result in a rather energetic release of energy!
Old Jan 17, 2012 | 11:35 AM
pettyfog's Avatar
Why you never throw away coil cord with any power handling capacity. I never had a vehicle with this but a co-worker showed me his fix years ago.
He cut off the coil cord from old set of headphones.. two equal length, soldered the three {approx} 20 ga wires together and installed them around the struts, strut in center of coil. He claimed his struts weren't lasting long because the defroster current pitted them.
Old Jan 17, 2012 | 04:35 PM
richphotos's Avatar
You make a good point, I was not aware that other vehicles did it this way, since i have only owned first gens.
Thanks for the tip, I will give soldering an attempt
richphotos
Oct 27, 2015 05:58 PM
Wexinlo
26
Apr 9, 2011 03:37 AM
GG_9_SE
Dec 16, 2010 02:00 AM
89jimmy22
Aug 14, 2010 09:39 PM
eddiep23
Jun 18, 2010 11:11 PM
