1993 K1500 Low Beam issues
Old Feb 23, 2014 | 03:11 PM
JSmithTN's Avatar
JSmithTN is on a distinguished road
Default 1993 K1500 Low Beam issues
I own a 1993 K1500 that recently developed a headlight issue, I have lost both of the low beam lights at the same time, I still have high beams.
I have checked the lamps, replaced the dimmer switch and I have had no luck resolving this issue.
Thanks for any help.
Old Feb 24, 2014 | 12:19 AM
abig84's Avatar
check fuses?
if not, on older trucks if the bright switch on the column went out it would cause your head lights not to work.
i dont know the proper name for it but when you pull your turn signal lever to engage your brights theres a bar that goes from the lever to a little switch halfway down the column that switches between low beams and high beams. ive seen them go bad before
but im thinking 80s trucks. not quite sure if yours would be too new but should be pretty easy to test if it is there. should have 3 wires going into it, one power and then it alternates it between the other two for low and high beams
Old Feb 24, 2014 | 05:38 AM
JSmithTN's Avatar
There are no headlight fuses located in the fuse panel, I have already replaced the dimmer switch that you are referring to. I believe that there has to be a relay somewhere that I haven't found yet, I have check the under hood terminal center and there is not one there.
Thank you.
Mike4x4ing
Jul 6, 2013 01:21 PM
marine
Jan 28, 2010 07:05 PM
evlblkwpnz
Dec 18, 2009 08:26 AM
chevyman09
Dec 7, 2008 07:58 AM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
