1994 GMC Jimmy S15, 1st Generation Blower Motor issues
Old Nov 12, 2023 | 09:04 AM
Reaper52's Avatar
Reaper52 is on a distinguished road
Default 1994 GMC Jimmy S15, 1st Generation Blower Motor issues
I recently purchased a 1994 GMC Jimmy S15, four door with 241,000 miles. Last night I went ahead and replaced the Blower motor and Blower motor resistor. Now I have a weird issue. The purple power wire has 12 volts, when you start the truck everything works. As soon as you turn the truck off, and then turn it back on the Blower motor no longer works, but when you disconnect the power wire, then reconnect it everything works. I was wondering if anyone has ever had a similar issue?
Old Nov 18, 2023 | 11:56 AM
GeorgeLG's Avatar
What's the voltage on the purple wire when the blower motor is running and what is that voltage when it is not running? Where are you connecting the ground probe for the meter?
George
Bobbymac
Nov 2, 2021 06:27 PM
94chev
Nov 28, 2012 05:47 PM
BLKLBL
Nov 5, 2012 07:04 AM
tred5357
Jun 4, 2011 11:23 AM
a_tack
Feb 17, 2010 04:44 PM
