1995 Blazer LT w/4.3 4wd concerns
Old Oct 29, 2014 | 02:33 PM
cavalry6869's Avatar
cavalry6869 is on a distinguished road
Default 1995 Blazer LT w/4.3 4wd concerns
I picked up this Blazer as something to play with and let my daughter use. I had a battery drain problem that I have already repaired but still have one more problem. Nice clean body with the visor over windshield.
The 4WD H/L lights keep blinking. I am guessing it is something to do with the 4WD. Not engaging all the way or something.
Vehicle seem to run ok with a lumpy idle (I am guessing the spyder). Suggestions where to start? Ed
Old Jan 5, 2015 | 09:13 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default 4wd Hi / Lo
If your 4wd Hi / Lo indicators on the dash are blinking , I would check the wiring first.
I remember once having the wiring to the Transfer Case disconnected or not every wire connected at this 4 WD indicator section of the dashboard ---and these two lights , like what you mentioned, sat and flashed on and off at me !
Old Jan 23, 2015 | 03:13 PM
cdubbin90's Avatar
cdubbin90 is on a distinguished road
Mine does that too. I just picked mine up and it actually got stuck.in 4lo and that's all the lights would do is flash and flash and eventually throw the service 4x4 light n disable the switch all together. I had a bad switch also but that wasn't the reason why it wouldn't cone out of 4 lo the actuator was stuck what I ended up doing was driving slowly about 5ish mph and kept hitting the button n finally after hrs of messing with it while not moving it came out but mine if in neutral and I hit the 4x4 button it just flashes but once I put it in drive while holding the breaks it engages
jug
Nov 7, 2009 12:04 AM
Boosted95PGT
Dec 6, 2006 01:34 PM
*TLR*
20
Feb 21, 2006 12:20 AM
*TLR*
Feb 13, 2006 07:02 AM
