2000 Chevy blazer 6 pin square trailer plug need help to wire up
Old Jul 30, 2021 | 01:49 PM
Marco75123's Avatar
Marco75123 is on a distinguished road
Default 2000 Chevy blazer 6 pin square trailer plug need help to wire up
I need help with wiring a 6 pin square traler plug to my Chevy blazer which wires goes to which ones do I use all 6 or 4 please help thanks
Old Jul 30, 2021 | 02:15 PM
White - ground
Yellow - left turn
Green - right turn
Brown - running lights
Blue - brakes?
Light green - backup lights?
Old Jul 30, 2021 | 02:49 PM
GeorgeLG's Avatar
Where are those 6 wires coming from? Your truck only provides 4 wires in the oem trailer wiring tucked up near the spare tire.
George
Old Jul 30, 2021 | 03:15 PM
GeorgeLG's Avatar
Disregard my last transmission, of all the things I have lost I miss my mind the most. I will assume that those are your vehicle wires. In order to give you the decode, we need the 6 pin square pinout or at least the item being towed. This is not a common trailer plug and appears to have more than one pinout. Tom's vehicle wiring is correct incl. the ? marked ones.
George
Old Aug 1, 2021 | 09:25 PM
Marco75123's Avatar
Originally Posted by Tom A
White - ground
Yellow - left turn
Green - right turn
Blue - brakes?
thank you it all worked
Old Aug 1, 2021 | 09:29 PM
Marco75123's Avatar
George
one set is off of plug I bought for my jayco pup. Which I switched with 4 pin and my blazr doesn't have 4 wires tucked under bumper it has 6 factory that's how many there, were I figured it out with you alls help
Old Aug 1, 2021 | 09:32 PM
Marco75123's Avatar
not on my oem it's 6 wires that were tucked and I have the manual that says and has 6 wires on my 2000 Chevy blazer not 4 but I only used 4 last 2 are light green light blue backup an auxillary lights or watever
Old Aug 1, 2021 | 09:40 PM
Marco75123's Avatar
Default Update everything works but something not right
Tom all my lights work now during the day well the lights work great and everything but when I turn my taillights on my 94 jayco pup and I hit the brakes or signal only when lights are on the light comes on but Barley you have to put your eye close to see the bulb like it's dimm an same thing for with signal but my blazer lights brakes signals are bright an normal
Old Aug 2, 2021 | 09:11 AM
That sounds like a grounding problem. I would check where the white wire is connected to the trailer frame, and also where the lights themselves are grounded. You may have a poor connection that's good enough to complete the circuit, but drops voltage under higher loads.
Old Aug 2, 2021 | 11:03 AM
Marco75123's Avatar
OK Tom I will check that out with everything you said and see what the problem is... Thanks I'll update soon.
RedValor
Sep 3, 2020 08:27 PM
Walleye Hunter
Jul 30, 2020 08:45 AM
rexazz2
Feb 12, 2013 07:41 PM
jmack15
May 2, 2010 05:45 PM
WolfPack
May 31, 2008 08:11 PM
