2000 Chevy blazer 6 pin square trailer plug need help to wire up
Disregard my last transmission, of all the things I have lost I miss my mind the most. I will assume that those are your vehicle wires. In order to give you the decode, we need the 6 pin square pinout or at least the item being towed. This is not a common trailer plug and appears to have more than one pinout. Tom's vehicle wiring is correct incl. the ? marked ones.
George
George
one set is off of plug I bought for my jayco pup. Which I switched with 4 pin and my blazr doesn't have 4 wires tucked under bumper it has 6 factory that's how many there, were I figured it out with you alls help
not on my oem it's 6 wires that were tucked and I have the manual that says and has 6 wires on my 2000 Chevy blazer not 4 but I only used 4 last 2 are light green light blue backup an auxillary lights or watever
Tom all my lights work now during the day well the lights work great and everything but when I turn my taillights on my 94 jayco pup and I hit the brakes or signal only when lights are on the light comes on but Barley you have to put your eye close to see the bulb like it's dimm an same thing for with signal but my blazer lights brakes signals are bright an normal
OK Tom I will check that out with everything you said and see what the problem is... Thanks I'll update soon.
RedValor
Sep 3, 2020 08:27 PM
jmack15
May 2, 2010 05:45 PM
WolfPack
May 31, 2008 08:11 PM
