2000 chevy Blazer Fuel gauge problem
Old Oct 8, 2012 | 04:21 PM
Harold Spears's Avatar
Harold Spears is on a distinguished road
Default 2000 chevy Blazer Fuel gauge problem
I have a 2000 Chevy Blazer 4wd V6 Vortec, I bought this vehical from a used car dealer and they had to replace the fuel pump. Ever since they replaced that, the fuel gauge has been jumping from empty to full.
When I turn the vehical off and get out the fuel gauge jumps up to 3/4 but then jumps down to empty when I open any of the doors, and then jumps back up after I close the doors. While I am in the vehical with it turned off, I could go to adjust the power seats it jumps from 3/4 back down to empty.
If anyone knows what is causing this please let me know I don't want to start on taking anything apart untill I could pin point the cause.
Thank you
Old Oct 11, 2012 | 12:20 PM
jtbwatson's Avatar
jtbwatson is on a distinguished road
i had this issue, but it got fixed once i replaced the fuel pump o.O
Old Oct 11, 2012 | 09:43 PM
rriddle3's Avatar
Quite possibly was replaced with an aftermarket brand gauge rather than AC/Delco. Try this article:
98+ Fuel Gauge Diagnosis
Old Oct 11, 2012 | 11:03 PM
Rottidog's Avatar
I'd take it back to the dealer & say fix it right this time.
That link rridle posted is good, but IMO it should be the dealerships issue, not yours.
Old Oct 15, 2012 | 05:41 PM
Ok update on the topic. I took the battery cable off and checked the gauge it stayed at 3/4 of a tank, then i hooked the battery back up and started the blazer. Then I got under the truck and unhooked the cable to the sending unit it stayed below empty. With the sending unit still unplugged i turned the engine off and pulled the key out the gauge jumped back up to 3/4 and also the temp gauge jumped up. The same thing happened like i mentioned in the first post, I open the door and both of the gauges jumped down.
Old Aug 13, 2014 | 09:01 PM
blue96blazer's Avatar
blue96blazer is on a distinguished road
Default Wondering gauge
I'm going to recommend something to you that I just did on my 96 blazer. Put 10 gal of gas in and dump in a 20oz bottle of royal purple MAX CLEAN. i had the same problem and tried that. Half way thru that 10 gal. My gauge started working great. The sensor gets a buildup on it and causes erratic readings.
The max clean cleans everything in ur system. It's awesome. 16 bucks walmart. Worth a try.
Blais
Oct 25, 2013 08:41 AM
MarkyMarc
17
Mar 8, 2013 08:25 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
