2000 Front Passenger Window
Old Mar 23, 2012 | 06:43 PM
michaelg793's Avatar
michaelg793 is on a distinguished road
Default 2000 Front Passenger Window
Will NOT come up!
All other windows work wonderfully, but this one won't.
Until today, the front passenger window has worked just as well as the others, but suddenly it has crapped out..when I press the window button, there is absolutely no response, no matter whether I try to move it up or down. I don't think it's getting any power either..
Can somebody help me out, I REALLY don't want to have to drive around with a trashbag over my door.
Old Mar 23, 2012 | 07:27 PM
warthogdriver's Avatar
try taking the switch off the door and cleaning the contact first on each door.
i am guessing you have the buttons on both driver and pass door itself that operate the window.
when mine acted up i was lucky and one of the switches was corroded.
if that doesnt help the motor on the window itself may have went out. test for power at the connector to the motor itself for power...then if you have power and no go on the motor...then probably motor itself.
hope that helps...good luck in your hunt.
Old Mar 23, 2012 | 08:25 PM
Thanks for the advice, I took the driver side door panel off, and after a minute or two of examination, I discovered a thin yellow wire that was severed. I spliced the two parts back together and all is well.
Old Mar 23, 2012 | 09:07 PM
cool cool, best fixes are the easy ones.
drpcken
Aug 7, 2010 09:56 AM
98BlazerLS
Oct 27, 2008 08:23 PM
aaronjohn20
Mar 20, 2008 12:51 PM
bowanna03
Jan 8, 2007 11:23 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
