2002 hid
as long as I only put hids in the low beam I souldnt have any problems with the drls? I don't use high beams much so I don't think I will want the headache of the drl and the high beam fighting each other. thanks for any info you guys can give me
i have only hids in the lows and havent had problems for 3 years, all the sudden the hids wouldnt turn off unless i did the over ride by hitting the dome override button 3 times. heres what i did to make it work.
i disabled the auto head light sensor (which i think was bad anyway) On the dash, in the passenger speaker grille i put a 2.2k ohm 1/2watt resistor where the sensor goes
follow this links instructions it worked perfectly for me. and i DID NOT have to disable the drls, just the auto headlight sensor.
AHL and DRL How To's - S-10 Forum
Good luck man
skygodtj
May 23, 2012 09:08 PM
g_mike
Sep 13, 2009 11:43 PM
