2002 hid
Old Sep 2, 2013 | 03:42 AM
Killmonk's Avatar
Killmonk is on a distinguished road
Default 2002 hid
Was just wondering if anyone has found replacment HID lights for the dayrunning and High beams?
Old Sep 2, 2013 | 11:04 AM
richphotos's Avatar
No, HID's hate DRL's....
Old Sep 2, 2013 | 12:26 PM
Thogert's Avatar
You can make it work, but the key part of that phrase is the word 'work.'
Old Sep 2, 2013 | 01:13 PM
richphotos's Avatar
^true "work"
Old Sep 2, 2013 | 03:02 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
as long as I only put hids in the low beam I souldnt have any problems with the drls? I don't use high beams much so I don't think I will want the headache of the drl and the high beam fighting each other. thanks for any info you guys can give me
Old Sep 2, 2013 | 03:06 PM
Thogert's Avatar
The only problem would be the auto head light function. It likes to turn on the hids right when you are starting the truck, and the ballasts for the hids don't like that much.
Old Sep 2, 2013 | 03:55 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
i have only hids in the lows and havent had problems for 3 years, all the sudden the hids wouldnt turn off unless i did the over ride by hitting the dome override button 3 times. heres what i did to make it work.
i disabled the auto head light sensor (which i think was bad anyway) On the dash, in the passenger speaker grille i put a 2.2k ohm 1/2watt resistor where the sensor goes
follow this links instructions it worked perfectly for me. and i DID NOT have to disable the drls, just the auto headlight sensor.
AHL and DRL How To's - S-10 Forum
Old Sep 2, 2013 | 08:12 PM
Thanks for the info. I'm not sure if my 97 blazer has the auto lights feature or not but I will keep that in mind
Old Sep 3, 2013 | 08:31 AM
er0ck273's Avatar
Check your right dash speaker grill. If you have a black bubble you have auto headlights. Or if you dont have to turn them on at night lol.
Good luck man
skygodtj
May 23, 2012 09:08 PM
blazerboyz
Jul 30, 2010 09:44 PM
g_mike
Sep 13, 2009 11:43 PM
jagblazer01
Mar 9, 2006 10:43 PM
blue_green_rider
Feb 7, 2006 10:44 AM
