2004 Blazer seat wont move forward/back
Old Oct 25, 2020 | 02:32 PM
OrangeMango's Avatar
OrangeMango is on a distinguished road
Default 2004 Blazer seat wont move forward/back
So my girlfrind always adjusts her seat when she drives, everyday, and i believe shes burned out the motor because yesterday it stopped moving, mostly.
So the up and down works but pushing forward and back looks like the left side works but right isnt moving and it can only go so far before it sounds like the motor is dieing but im assuming thats because the right side not moving is binding the left and the motor will break if it trys to keep going.
I took off the plastic cover on the left side and the black cover for the motor. Removed the center console too. Theres a plastic cap for a huge philips so i used a flat head to remove it on both sides to see the rod ends. The driver side moving fine. The passenger is not moving.
I was reading another forum and they said it could stop working if the ground is corroded but could that cause the motor to stop on only one side?
Probably going to picknpull to get the entire seats base and hope it works cuz idk if anywhere sells aftermarket motors.
I know its a bit odd but if anyone has any input please help.
Old Oct 25, 2020 | 02:35 PM
Instant update.
Now the motor has stopped going forward and back on the left side and is dead. I cant test the volts because ive misplaced my volt meeter otherwise i would.
JCHWB47
Aug 12, 2020 04:50 PM
MrFreeman
Jan 21, 2018 05:59 PM
blueandwhite
Jan 22, 2015 06:30 PM
neospyder
Dec 21, 2011 12:07 PM
TheDesertFox
Nov 18, 2006 10:22 AM
