4 100 watt KC's
4 is too many. Best to wire them up in pairs. Mine are wired in pairs - the 2 inner ones on it's own switch & relay & the 2 outers on it's own switch & relay. All the lights are powered directly off the battery with a 40 amp fuse.
agreed. if you want you can run 1 switch to both relays but i would make sepurate wire runs, most kits dont have thick enough wire for one thing and putting them together might be to much on the relays. wire in pairs, 40 amp fuse, and make sure its a good ground please.
postal0dude
36
Apr 28, 2013 10:03 PM
dimmuborgir6nik6
Mar 10, 2008 09:57 PM
