4 100 watt KC's
Old Dec 28, 2009 | 10:59 PM
Blzrmudslinger2020's Avatar
Blzrmudslinger2020 is on a distinguished road
Default 4 100 watt KC's
okay so i had to lights but i just got the other pair. but i wanna if i can include all four lights in one circuit. how are some of you guys running your circuits.
Old Dec 28, 2009 | 11:11 PM
kiwiblazer's Avatar
4 is too many. Best to wire them up in pairs. Mine are wired in pairs - the 2 inner ones on it's own switch & relay & the 2 outers on it's own switch & relay. All the lights are powered directly off the battery with a 40 amp fuse.
Old Jan 1, 2010 | 12:15 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
agreed. if you want you can run 1 switch to both relays but i would make sepurate wire runs, most kits dont have thick enough wire for one thing and putting them together might be to much on the relays. wire in pairs, 40 amp fuse, and make sure its a good ground please.
Old Jan 2, 2010 | 02:51 PM
Benedict1337's Avatar
I have mine all on one relay. I had to get a bigger fuse but other than that it should work.
postal0dude
36
Apr 28, 2013 10:03 PM
dimmuborgir6nik6
Mar 10, 2008 09:57 PM
Idriveachevy
Dec 19, 2007 06:14 AM
Canadian88
Jan 27, 2006 05:20 PM
