87 k5 electrical issue
Old Sep 3, 2014 | 08:44 AM
87k5Beast's Avatar
87k5Beast is on a distinguished road
Default 87 k5 electrical issue
I was driving it the other day and noticed I had 8-10 volts. I shut it off to visit a friend and go to leave and try to start it and it cranks slow for a second then here a pop and saw a small amount of smoke come out of the passenger side under the hood. Now there is no power to the dash, power locks, power windows and the starter won't engage. I have headlights and dome light. What could be the problem?
Old Sep 3, 2014 | 02:53 PM
Maggz's Avatar
Maggz is on a distinguished road
Blown fuseable link on the master wiring harness could be an issue. The low voltage could be caused by a bad voltage regulator (which is built into your alternator). The fusable links are typically within the first 3 feet of your wiring harness which comes off of the battery and might connect to a junction block and separate from there. It might be on your inner fender mounted somewhere up top. Hope this helps you.
JoSHN
Sep 14, 2012 04:56 PM
Bauer318
Nov 1, 2006 04:06 AM
regisvu
Sep 19, 2006 12:15 PM
jdpilot
Oct 24, 2005 04:01 PM
Painkiller1990
Sep 17, 2005 02:34 PM
