92 Blazer S10 gauge issues
Old May 7, 2017 | 07:13 PM
Pikagrue's Avatar
Pikagrue is on a distinguished road
Default 92 Blazer S10 gauge issues
My speedometer, odometer, trip odometer, and voltage meter all work, but my oil pressure meter, gas gauge, and temperature gauge do not work. I have checked and tested all fuses, but that does not seem to be the problem.
Gauges are analog. Service engine soon light is on. Check gauges light goes on intermittently.
I bought the car fairly recently - the gauges have never worked since I have been in possession of the car. The previous owner installed a new stereo system, and I suspect that they may have screwed up the wiring when they did so.
Any ideas?
Old May 8, 2017 | 12:35 PM
abig84's Avatar
possible if they cut the ground wire or spliced into it.
there was a problem with the older 80s blazers where the gauges would become all screwy, in the case of those there was a small ground wire that screwed upwards into the dash right at the bottom front corner of the dash and it would come loose.
i dont know if your truck is too new for it to have the ground wire there but its worth a quick check, just stick your head under there and should be like a 1/4 inch bolt going upward in the left corner of the dash
Old May 13, 2017 | 09:51 AM
rtreftz's Avatar
rtreftz is on a distinguished road
Gauge cluster has a printed circuit board, it does not take much to disrupt the connection at connector. I would advise removing and cleaning the connection with an abrasive like Emory cloth.
er0ck273
Sep 1, 2013 11:45 AM
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
