2001 zr2 turn signal brake light problem
Old May 13, 2017 | 09:52 PM
Tom Zambori's Avatar
Tom Zambori is on a distinguished road
Default 2001 zr2 turn signal brake light problem
]I have a 2001 ZR2 and today my brake light and turn signal on the pass side stopped working. The front flashes fast but still works. I checked both bulbs and they are fine. I'm hoping it's not the multifunction switch. Any ideas? The other side and the 3rd brake light work perfect. I was told it might be the brake light switch.
any help would be appreciated
Old May 13, 2017 | 09:55 PM
[QUOTE=Tom Zambori;676549]I have a 2001 ZR2 and today my brake light and turn signal on the pass side stopped working. The front flashes fast but still works. I checked both bulbs and they are fine. I'm hoping it's not the multifunction switch. Any ideas? The other side and the 3rd brake light work perfect. I was told it might be the brake light switch.
Old May 13, 2017 | 11:57 PM
richphotos's Avatar
I would start with getting some new bulbs (even if you think they look "good" does not mean they are" If that does not work, I would start probing around with a digital multi-meter at the socket to make sure you are getting power and ground on the socket/s
Old May 14, 2017 | 09:39 AM
New bulbs. Did all the basic stuff. I was him a replace the brake light switch and see if that dies the problem. I do t think it would be the multifunction since all the other signals work. Just not the rear pass side. Same with hazards. All work except that one.
jasondis
Apr 5, 2014 04:54 PM
f-ten
Jan 8, 2010 07:45 PM
drummerdude
Dec 17, 2009 09:55 PM
tim_dean
Mar 30, 2008 09:02 AM
Jimonawing
Nov 16, 2007 02:38 AM
