92 S10 Blazer Issues...
Ok...so I am back...I have tore down and replaced the ingition switch..took out the gauge cluster took it down to a buddy had the soulders fixed on the back and still having serious issues with the electrical system..
So over all this is what it is doing still...
All the dash lights on the bottom are lit up...hazards highbeam check engine abs check gauges brake light all those are on...then the gauges such as oil temp and battery are all reading top line cant even see the needle...at that point it will not start....then the lights drop off it tries to start then the lights come back on and it dies out...
Now if I unplug the battery for a day its the shortest I have done it at it will start and run fine...but if I shut it off it starts the same crap over again...I am at a loss here and getting very frustrated as I have gone through and checked all wiring and yet to find a short replaced alot of the wiring as well...
I am starting to wonder if it is the computer...but at the same time I aint sure how the hell to even check if the computer is bad or not..
Any ideas? Anyone else with this issue?
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
celchlepp
Nov 18, 2008 11:16 AM
